I put Clazzio Leather seat covers in my current and my last Silverado,  Folks say it looks like OEM.  I say better, because you have options👍
Lou
This is why I buy a trim level that has leather seats....no need for seat covers.
I switched to Wet Okole truck seat covers, and it’s been a game-changer. Their seat covers are custom-fit, so they cover the entire seat, including the back. The neoprene material is thick and durable, which helps keep everything in place when slide in and out.
Edited by RJL1983
I put marathon seat covers on all my trucks,  custom made in Montana, you can add extra pouches on the fronts and backs if you like.  Fit is great
