Ever since I bought my truck new it’s been a weirdo. Intermittent loss of connection with CarPlay until I shut it off open the door and let it time out, Intermittent loss of backup camera guide lines, intermittent vibration at interstate speeds and at the same speed later in the day no vibration.
Lately the spirits have been angry. One day I started the truck with Chevy app and when I turned on the ignition I got alerts that my abs system failed and top speed was reduced to 62 mph. Again, turning it off opening the door and letting it time out problem gone.
Today I tried to start it and it acted like the battery was dead. Wouldn’t turn over and each attempt yielded a weaker click. I jumped it with the wife’s car and it started (under light protest). Drive it to auto zone and the battery, alternator and starter check out fine. Now I’m noticing the ac is blowing out the vents and floor vents even with floor off. If I select floor only it does floor only but regular vent does both now. Wtf??!!
Edited by IndMechJeff
Added features / options on newer vehicles equal added complexity, more wiring, and more ways things can fail. Prime example of that right here.
Impossible to diagnose with the limited info. We'd have to see codes, if any, and live data from a scan tool to even glance at the potential issue. That said, my guess is you've got something bringing down one of the many communication networks on these machines.
Then, there's the possibility that this is all just piss-poor build quality and nothing is wrong electrically. Having several systems fail all at the same time on a 5 year old 21st century vehicle is not outside the realm of possibility.  Either everything is failing at the same time (possible), or there's a communication issue causing multiple issues (very likely). The fun is figuring out which.
If you have limited or zero understanding of high and low speed CAN, MOST bus, and LIN networks, I'd start doing some intensive Google research on a local NON-DEALER (IMPORTANT!!!!!) shop that specializes in electrical gremlins, AND has great reviews - a tall order these days, I know. You might have to have to travel an hour or more to find one.
My best advice? STAY AWAY FROM THE DEALER with this one.
Edited by Jsdirt
Thank you so much for the prompt reply. I’m assuming the advice to stay away from the dealerships is suggesting this is a juicy cash grab opportunity for them?
Indeed it is! If you've got deep pockets, you won't mind. If you work hard for your money, you'll be livid.
Like I always say, this statement isn't to bash all dealer techs - there's some great ones out there. It's more a corporate bashing, since they screw their techs as much as their customers. The pay system encourages speed over thorough diagnostics. To troubleshoot failures like this, speed is the exact OPPOSITE of what you want to be doing.
Edited by Jsdirt
To expand on this a bit further so people understand ...
Say, theoretically, to fix a complex electrical failure it will take a combined 50 hours of troubleshooting, but the book time only pays 3 hours, GM isn't going to give you 47 free hours. They nickel and dime techs TENTHS of an hour over lunch breaks, and walking to the toolbox. 47 hours is absolutely NOT going to happen.
So what WILL happen is, they will continue to toss parts at the vehicle until the problem goes away. Sometimes it never does. Those parts are all billed to YOU, along with the associated labor to install them. You can see where this is going ...
You can't blame the techs - no one is willing to work for free, so you can't expect them to either.
Edited by Jsdirt
Again, thank you so much for taking the time to reply. I had no idea that’s how the dealerships did their techs. Gonna start asking around local mechanics.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
