06 Z71, leveled on 33's and im going through CV's about 2 times a year. Rarely ever put the truck in 4wd so thinking of just deleting. Extended travel
CVs around $400 but cant I just replace hubs with capped end 2wd hubs and remove axles? I can do this for half but want it to be safe. Rather not
try and take axle apart and use the ends but can anyone confirm 100% this will work? Thanks!
No photo description available.
I don't think 2wd hubs will bolt to the knuckle, It's not a big deal to pop the outer joint off the shaft, just a little nessy
From what I can tell its the same but just put hubs on the truck a year or so ago. Might pull one axle and just see if I
can tear it apart and keep the splined end, that way it wont cost anything . Thanks
Edited by DeeboSC78
Is it just a snap ring holding that outer end? just never taken one apart but cant be that difficult i wouldnt think
pull the  boot back and there is a clip where the axle slides into the joint, spread the clip open and the axle slides out of the joint. You might be able to find a tupperwear lid that fits the joint to keep the grease in and the dirt out
Will try this for sure
Ran out to my shop on my lunch break and pulled the worst of the 2 axles.. cut the boot off the end but didnt see any sort of clip but was also short on time. Beat the s**t out of it with a small sledge and it finally came off. Dont like doing it this way but if I can get by without spending $400 on HD axles im ok with it
Edited by DeeboSC78
    Tbhats2130
    Tbhats2130
  • Who's Online   0 Members, 0 Anonymous, 2,378 Guests (See full list)
