The other day the temp light came on but gauge showed ok. 35F degrees out. Not towing. No check engine light. 2022 ZR2 6.2 13K miles. Light stayed on when engine was shut off then went off. Coolant level was ok. On restart the light lit with all the others then went out per normal. Has not happened since or before. The menu doesn't have an option that I can find to display engine temp just transmission.
Do you have “ On Star” if so, you can call and ask for a diagnostic report. If there was a code, you can look it up or take it the dealer to read the memory. My 2021 1500 3.0  ( 49K miles) had a check engine light for no apparent reason. Called on star, got the report. Dealer said it was the “ coolant flow control valve” They changed the valve. Warranty item, so other than an inconvenience, no issue.
No numbers on  it but there the truck will have a coolant temp gauge you can turn on ...
It will have a 'red zone' to indicate it is too hot.
They are supposed to also have several DIC messages for high coolant temp conditions.
I don't know why the light is on, but the coolant temp gauge looks this this when displayed on the dash display shown in your picture.image.png.4007d2008c772f2dc5f1562597d542df.png
You might need to go into the dic setup to enable it and to place it in the location you prefer.
Thanks. I do have the temp gauge displayed at bottom of the display. It showed normal when the temp light was on. Not sure if the 6.2 has more than one sensor?
  • 1 year later...
I’m dealing with the exact same issue. My temperature light came on twice yesterday while driving, even though the gauge looked normal. Every time I pull into a shop and shut off the engine, the light disappears, and the mechanics say they can't diagnose it without the light active. It eventually came back on while I was driving again, so I’m headed to a third shop now for a full diagnostic. Did you ever find out what was causing yours?
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
