Hi Fellas
Well the 2024 Chevrolet 2500 Custom has been running fine so far,  although to be honest, I don't drive it a heck of a lot and using my older truck for dirty jobs .
I'm still below 3000 Kilometers .
I just now noticed a problem, there is condensation behind the plastic lens for the headlights, both sides, and strangely it is the same pattern in exactly the same spot on both sides
Any one else have this issue ?  I have only washed the truck 3 times and no high pressure water used . I'm sure this is a warranty issue !
Look forward to replies
Thanks
Edited by BCGM
spelling
Anyone with a 2024 with the same headlamp covers having this problem ?
Need help . Should I just take into the dealer  its under warranty
Okay I will post this here here as well . 2024 2500 HD Custom Trim level .Both headlights right and left side have condensation behind the plastic lens that covers the headlamp unit . Anyone else have this problem ?
Could it be that I have not driven it in awhile and the water vapour has built up in there and not dried out from the heat of the headlamps ?
This is a non LED headlamp system
Thanks
Thanks
Our team is sorry to hear of this condensation concern you have been experiencing and would like to investigate further on our end. So, we may learn more, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We will keep an eye out for your email.
I have sent an email
  • 4 weeks later...
Update to the headlight condensation . It's gone after about a month . Here's what I'm thinking without having looked under the hood to see if I may be on to something . I had washed the truck for about the second time and wanted to give it a a good rinse under the wheel wells . The front wheel wells have that felt type inner lining not plastic . I'm wondering if the water goes through that fabric and gets into the headlight assembly .If so that's not a good set up and needs to be addressed
Your thoughts please !
I know this thread does not seem like a big issue but if your using your 4x4 and enjoy keeping it clean it would seem to me that getting moisture in the headlight assembly every time you wash out the wheels wells is a problem
