2022 GMC Sierra 1500 5.3L. Puddle lights only come on for a split second. I’ve adjusted the timing to 120 seconds in the settings on exterior lighting but it’s not working. I’ve also swapped them out with a new pair, but they still only come on for a split second, then off. I’m wondering if I installed them backwards (passenger side on driver side and driver on passenger side). They weren’t even working before changing them out, that’s why I changed them out to begin with. Any help/insight would be much appreciate.
Edited by Todd Sickler
when they shut off instantly it indicates they are drawing to much power and the bcm shuts them off. i would unplug one side and see what happens, if still the same plug the one back in an unplug the other side
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
