Zaino
jr.parrish
yeah, that's tha place alright.  Before you buy it, read the post on the comparison between Mequiers and Zaino.  I think it's in the general forum.  I personally use Zaino, and find it to be a reat wax, and it lasts for quite some time, although not as slick all the time as when you finish waxing it ???   Just some food for thought.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
