Just figured I would share my experience with installing a Back Rack with my Flex Hard fold tonneau cover.   I didn't end up using the additional tonneau bracket and it worked out just fine with my between the rail cover.   I'll even be able to remove the cover completely without having to take the rack off.  I didn't really want to spend another $100 on the riser bracket.  Scored the rack and standard brackets for $150 yesterday.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 173 Guests (See full list)
