I have a 2025 GMC 2500 Sierra with Duramax. Its not in the shop for the 4th time for the same issue, but this time they had a recording computer hooked to it to see if they could diagnose it. So far they have been unable to figure out the cause of the issue which is it goes into limp mode, traction control light comes on, service light on, reduced accleration message. After shutting it off, giving a little bit and restarting, everything but the check engine light goes away. AFter it sits a day, that does away as well. Its giving P060C code. Softwares have been flashed multiple times, new gateway module put in it, and GMC regional tech has been there over 15 hours working on it and found nothing.
So when i took it in Saturday morning, the service manager saw that i had made note that i had the exhaust brake on. He immediately said this may be whats causing it. He said you can't use that unless on the highway and pulling a trailer of some sort, and that the owners manual states that. I have looked up the exhaust brake in owners manual and there is nothing saying you can't use it in town or without a trailer or anything to that affect. This issue has happened to me 5 times now since beginning of the year, twice with exhaust brake on, 3 times without it on so that alone tells me it is not the issue.
Has anybody else experienced this type of issue with exhaust brake? Been told you can't use it in town or without trailer? Given any conditions you cannot use the exhaust brake for? I feel like this is a copout basically because they don't know what else to say. They have a tech case open with GM and i have case open with GM also for possible buy back or something else if issue gets fixed. Anybody have any thoughts or experienced anything similar to this?
I think your analysis of the techs comments are accurate. Some people feel the need to say something even if they have nothing to say. Any claims made and not substantiated by a document or the manual should be dismissed. I would make note of this event and start keeping a log of any interactions going forward. Ask them to put everything in writing via an e-mail or text you can save. If it aint written down it didnt happen. This will help in the end if a resolution isnt found.
That's a line of horse.  Exhaust brake can be used any time you want to and it would not cause that code to set.
DTC P060C is Control Module Main Processor Performance.  It can set for the ECM or the TCM, and possibly other modules.  Its a computer processor issue that could be from an intermittent faulty ECM or TCM or wiring to those.
The GM regional tech should try an ECM or TCM (whichever is setting that code) if they have not already done so (instead of just flashing things) and see if anything changes.
Any chance you can ask them for a copy of the SAVI printout with DTCs and post a picture of it here?
I can ask for it next time i go there. I'm not familiar with that but i can ask. There were originally going to replace ECM I believe, but the engineers said not to cause it wasn't problem. Apparently there are multiple trucks out there with this problem and no fix yet. Not sure why the engineers think its not the problem.
  • 1 month later...
Just to give an update, the issue with the exhaust brake appears to be torque converter related. AFter much aggravation and fighting with it, they found the issue happens during deceleration when it goes into 5th gear around 35-40 mph. The engine rpm and the input shaft on tranny rpm are not syncing, which is causing the truck to go into derating mode and codes to come up. They put a new torque converter into it and it seems to have fixed the issue at hand, however now it leaks tranny fluid from what appears to be the input shaft area of transmission. I'm done fighting with it. The truck is going back to GM for a buy back hopefully and i'll start over with another new one.
  • Sad 1
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
