Third brake light stays on. Batteries (new) keep draining even before the third brake light stayed on. (Replaced brake sensor)
code reader shows BCM error.
my truck is deleted. If I have BCM replaced and reprogrammed to truck will that effect my delete? The shop who deleted my truck is on vacation for a week. Batteries are 2 months.
dealership won’t tell me since truck is deleted.
the shop that deleted my truck is 4 hours away. They will delete my truck anytime for free. If I need it redone.
BCM should have nothing to do with a delete as far as I know.  That's all on the ECM.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 173 Guests (See full list)
