4L60E Bracket
I posted this in LD too but I seem to have bent the shift bracket on my transmission. :thumbs::):lurk::flag::lol: I need to find the part number for a replacement bracket. Does anyone know what that may be? Mine works OK,but the shifter is sloppy seeings that bracket is bent. Any help is appreciated. :bs::bs:
Thanks,
Scott
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
