Hi, on my 2019 high country I have been chasing a steering issue where I’ll be driving and when I need to move just the slightest bit to the left the steering feels like I am going to spin out of control. I have replaced the left side suspension and had alignments done and I still have this problem, anyone else have this issue?
Check the ground strap under the hood. Passengers side from the firewall to the frame. Look for corrosion or green rot. Lots of problems caused by this ground.
Already replaced the ground straps. In anticipation of this happening. So my guess is I may have a bad steering rack? It drives fine it’s just barely turning left it feels like it’s just going to break loose then catches itself.
We take your concerns seriously, and would like to learn more. We ask that you reach out via email at [email protected] so we can assist. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
How many miles on your truck?
98,000, we did look at another ground strap today and it was green, so I ordered it and will replace it tomorrow. I hope it’s a bad ground. I don’t want to be replacing a steering rack.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,117 Guests (See full list)
