Hi All,
Looking for help finding a part number.  I stripped a couple nut inserts in the process of installing the multipro hitch cover on my 2025 Denali Ultimate and trying to find replacements.  I had to remove the plastic cover circled in the diagram below and as you can see, the hardware to mount is not shown.  There are 10 screws with T20 torx heads that hold the panel on and go into a stamped nut insert which is what i stripped out.  I went through every piece of hardware in the Body Hardware category on the GMC parts ordering site and found some similar parts and GM calls them "multi-purpose nuts" but didn't see the exact one I need.  The ones I need are green plated and about 16mm across the top and snap into square holes in the tailgate that are 8.5mm x 8.5mm.  They look like the 2nd picture below except they have a green color.  Any help finding the correct part number is much appreciated.  thanks.
The catalog says you need the whole plate.  The smaller nut is serviced separately, the larger one you seek is not and is part of the panel.  87862555 is the current #.
1 hour ago, smokeyburnout said:
I apologize for any confusion.  The only thing I need is the smaller nut.
No problem and perhaps I made a misunderstanding?
11570654 is the nut you posted a picture of.  I'm looking at one in my hand, somewhat of a blue or green tint.  The square insert end is like 8.25mmx9mm?  9mm being the side with the tabs that would hold that in.
I think you answered my question and found what I was looking for!  Thank you!  Those dims are really close to what I'm measuring as well and if they are bluish-greenish, they must be it!  Thanks again for the help!
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
