Is there such a thing on the market to replace the giant "CHEVROLET" on a 2020 to 2023 LT/LTZ HD with a bowtie?  I have not found it myself, but thought I would ask the question to be sure I'm not missing anything.  Thanks.
I am not aware of anything aftermarket-wise, but if you wanted to stay with OEM parts your best bet would be to swap out the grille to a 2020-2023 High Country grille. You would also need a paint-matched grille surround since it is different for the High Country grille.
Yeah, I've debated doing that but I get derailed by needing that painted trim piece.  If it was available factory colored I'd probably have done it already.
It is possible to find them painted from a parts recycler. Some of them even have new surplus parts directly from GM. It would be a bit of work calling around and seeing who has/can get what, but it is doable. You'd probably be looking at ~$500-$700 for that painted piece.
Another option is if the dealer you order the parts from has a collision center, they can paint match the part for you if you. Just be sure to give them one of the painted trim pieces you are replacing on your truck so that they can match the paint properly.
Edited by Ry Guy
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
