I have a leak coming from the headliner down to the seatbelt and floor of the second row passenger side. I lowered the headliner a bit when it was raining to see if I could locate the leak and it seems like it was coming from the sunroof. The only part that gets wet is on the pillar behind the rear passenger door the headliner part and seatbelt and floor in that area. Would I need to remove the entire headliner to clean the drains? Or is there maybe a different reason it’s leaking into the cab?
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 0 Anonymous, 763 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
