I hear a knock when I start it, the spark plug is soaked with gas like it’s not burning. So the knock I am hoping is from fuel.
i replaced spark plug, i seen spark from coil pack to the fuel plug wire (all new wires now also). I even switched swapped coil pack with #3.
i thought maybe one for dumping too much fuel and replaced it.
compression while cranking is around 155-160psi.
is there something I could be missing?
If it was valve or lifter issue I would think compression would be low.
any help is appreciated.
It looks like you covered all the bases. About the only thing left I can think of would be injector voltage,harness or bad new injector.
Edited by Sneaky pete
Ask about code, was stated in title.
    tblt44
    tblt44
  • Who's Online   4 Members, 0 Anonymous, 552 Guests (See full list)
