My rack & pion started leaiing today on my 13 suburban   it's leaking from the connection rit under the oil pan   is there a high pressure seal that goes there. ?  I really dont want to have to change the whole unit. Any suggestions?
Pretty sure they are a non-serviceable item, going to need to replace the whole rack. The metal used has a tendency to enlarge itself over time and start to leak, making replacing the seals impossible.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
