Hi, I have a 2014 GMC Sierra with a vin code H 4.3 lv-3 with Vvt. It has failed and I am looking for a low mileage 4.3. I am on a tight budget. If it was an AFM/dod delete that would be awesome. I live in Fort Walton Beach, Florida East of Pensacola. My email is [email protected] Thanks! George
Curious. How many miles did you wring from the first motor? What happened to it?
What does car-part.com shows for engines in your area?
You can search that site for engines within hundreds of miles of you. Otherwise maybe try marketplace too.
10 hours ago, thedream craftlife said:
283,000 miles. Haven’t gotten it apart yet to know what happened.
Did it use oil? If so when did it start and how much did it use? I have one at just under 200K so this is interesting to me. Thanks.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 364 Guests (See full list)
