1 of my fans keep running,but shut eng off and it stops,temp gauge reads normal and it drops when sitting maybe cause of the fan...gonna change sensor and see,but if it reads how can it be bad?
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
