Soler Performance DLX throttle controller for 2024+ Chevy Traverse, GMC Acadia, and Buick Enclave
• Improves throttle response and pedal feel
• Multiple driving modes and adjustability
• Bluetooth app control and on-device control
• Plug and play installation
• No tune required
• Vehicle-specific design
Designed to improve daily driving response and overall drivability.
SE0530 DLX Bluetooth Throttle Controller:
Enclave 2nd gen (2022-2024) | Enclave 3rd gen (2025+) | GMC Acadia 3rd gen (2024+) | Traverse 3rd gen (2024+)
https://www.solerengineering.com/generalmotors/se0530
Discount Code: TIFF5OFF
If you have any questions about throttle controllers for your setup, feel free to reach out. Always happy to help.
Tech support: 251-716-8077
General questions and sales: 251-468-9786
Happy Friday and happy May 1st. Start the month off right with Soler Performance for improved throttle response and better airflow into your engine. Use code TIFF5OFF at checkout.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 806 Guests (See full list)
