SS engine Swap
Hello all,
I have an opportunity to purchase a wrecked Silverado SS. With the salvagable parts I would like to swap the SS 6.0 L in place of the 5.3 L that is currently in my truck.
I kow that the engine will be a direct bolt in, but I have a few questions about the electronics that I don't really understand.
1) In order to swap the engine, will the whole engine wiring harness need to be swapped as well, or just the ECM?
2) How are the automatic transmissions controlled? And how does the transmisson affect the engine performance? Let me explain further.....
I know that the SS has an electronic all-wheel drive transfer case, while my '00 silverado has a electronic selectable transfer cas (2wd, 4wd, Autotrac, and 4 Low).
3) Is the Autotrac the same as the All-wheel drive setup on the SS?
4) Would it be possible to use my exsisting transmission/transfer case so Keep 4-low and run the truck as a traditional 2wd on the highway?
5) does anyone know of any sensors that maybe included on the SS that may affect the engine performance that may not be on the standard silverado. (wheel speed sensors and stuff like that)
ANY help would be appreciated.
Thanks
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
