Thermostat Change
I am going to be changing the thermostat out for a 180 on Saturday. My westers should be in by then and I had Lyndon program the new PCM for 180 instead of 210.
Here is the problem. The leasing office at my apartment complex has given me several friendly reminders about not working on cars in the complex :cheers:
How much time do you think I need to swap the old one out with the new one? How much coolant am I going to loose from disconnecting the lower radiator hose? I want to change everything out really early on Saturday morning before they start making there rounds and the fact that the engine will be cold from sitting all night. Thanks for the help! Nick
Here is the problem. The leasing office at my apartment complex has given me several friendly reminders about not working on cars in the complex :mad:
I did this on my LS1 Corvette... Easy job but MESSY!
Get 2 pails (Clean) a few gallons each..
Put one under the radiator drain and the other under the T-stat.
Open the drain on the radiator and let it run out. Open the expansion tank too.
Leave the main hose on the T-stat and just unbolt it from the motor.
Swing it up high in the air once unbolted and remove the hose clamp.
Have the other stat ready to swap. The reason you do this is to keep that hose full of coolant.. Or it just runs all over the garage floor like me.. :cheers:
Rebolt it back again, close the drain cock. and refill the system with the coolant you caught in the buckets. Hopefully you will have it done in less than 1/2 hour.
Well a budy came over tonight and we conquered that mess. I had one drain pan and very quickly realized that wasnt going to work :confused:
Got the new one in and ended up adding quite a bit of coolant (drain pan wasnt clean.)
Now we wait and see! I put the Westers in there tonight. Immediately noticed the lower exhaust tone and went for a spin. I know it is going to take a couple of hunderd miles to get it fully relearned (living in houston that is easy) but WOW I couldnt believe how much harder it pulled from off the line! The only thing I wish was that the shifting was a little bit firmer, but other than that I can wait to see what ends up happening! :sleep:
Also, I'm curious: all the aftermarket stats I've been finding all come with the housing... at like $50+ bucks. With only 7500 miles on my truck, do I really need to change the housing ?? If not, where can I get a stat for a little less $$$ ??
And the reason to run a cooler stat is to lower the overall engine temp to help ward-off detonation, and cooler also means a denser air/fuel charge.
Thanks.
Thanks.
It is one piece design. I looked at the new one for an hour trying figure out how to take just the thermostat out. I couldnt do it. It looks like the housing is cast with the new thermostat in the mold!
I got mine from Tom when I did the GP for the Westers. The quailty of the new one is as good as the OEM. The only real pain besides the mess was making sure that gasket was on there right. :confused:
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
