Just got my Mother's Clay kit
I have a 99 GMC Z71 and i noticed the paint (which still looks good) is not real smooth after I wash it. Then I started to read about the clay bar usage and finally ( after a long time) found some down here in corpus chrsti. Tomorrow if the weather holds I plan on using....anyone got any tips
todd :thumbs:
Wash first. Dry. Then in the shade on cool vehicle use the clay. Use adequite amount of QD for lube. DO NOT use any pressure with the clay. Occasionally wad it upand rotate it so you are using a clean section of the clay. After you finidh follow up with a good polish and then a wax. You should plan on most of the day to do it right.
In addition, practice first on your freezer, washer, dryer, or fridge. Get a feel for the clay bar. It is an amazing product and will do wonders, but the tecnhique has to be rehearsed first. As the letter above this one sez, use plenty of lubrication.
Most don't agree with me, when you run out of lube, use Windex or any glass cleaner. Works just as well, but this is just my opinion.
And again, rehearse on a large appliance.
you can also here it working and will feel it too as it removes the bad stuff.
Never never drop it!!!
  • 1 month later...
Yup take your time, keep it well lubricated. When your done with an area use a clean terrie cloth to remove the lubrication. You really can feel the difference when running the clay.
I found it very interesting the parts of my car that "needed the most" Hood, 1st quarter panel, rear quarter panel and Tailgate. Area's were the worst and my truck is not even a year old.
Dont forget you will be waxing her once your done with the clay process, the whole thing from soap to wax took me almost 4.hours
But it sure is worth it when your done :lol:
If you are REALLY Anal like most of us are on here... LOL
After you finish with the Clay bar, wash it again to get the goop off,
then I followed it up with Mothers Pre wax cleaner to pull anything else off, and then the glaze / sealant to hide swirls, then a good coat of carnauba wax...
That truck will shine like a Mo Fo when its done.. .takes all day though
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
