Which direction to fire sub?
I'm hoping to replace a Bazooka tube with a 10" sub under the rear passenger seat of a 2001 extended cab silverado. I have a 5-channel Directed Amp that will put out enough power (can't emember the specs right now). Is a down-firing box better that up-firing or front-facing? It seems like most of the custom fit boxes are down-firing, is that the better way to go?
Also, any recommendations on 10" subs? I was thinking maybe JL based on some review I've seen online.
Thanks for any opinions
I'd say for space issues, go with a down firing box. They sound prety fricken good on most trucks too. For subs, I'm not sure where you can find them in your area, but I'd really reccomend a 10" Arc Audio subwoofer. I have their KAR series 12's, and I've only got a 550 watt amp for the both right now, but OMG! They sound sooooooooooooo good, never distorted, never too low or too high, and when I wanna show someone up I can just BLAST it. My cousin has the 10's, same models, nder his F-150's back seat, you would think they're 15's! For the money, you can't go wrong. They fit well in most shallow boxes and perform so good it's unbelieveable.
Check em out Here
if you have enough power, get a 10" s10l7 kicker solobaric. If that's too much, go with a kicker compVR. they both hit hard. compVR sounds good sealed, firing down, but the solobaric sounds alot better ported. Then space is just the issue :thumbs:
Really the sub is up to you... I prefer Diamond Audio.... but Kicker isn't bad either.... I have mine set up in a down firing set up.... one ten, getting around 500 watts.....
Loud enough for me
I had a regular firing set up, and it seemed like when the seat was down, it would muffle the sound a little...
I've had up firing subs, down firing subs, and rear firing subs (in a suburban), but for a truck, I kinda like my up-firing kicker better. When I had the downward facing box and wanted to show-off the bass, it would shake the car so much that my multi-disk would skip. Now with my up-firing box it is still loud as all hell, can be heard outside the vehicle better, and does not make the multi-disc skip. Another plus of an up-facing box is tha tyou can get your girlfriend/wife to sit in the back very easily... :D:crackup:
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
