4th Annual Sport Truck Shootout
AnniesSS
Once again, I'd like to invite everyone to attend the 454SS North American Truck Club's 4th Annual Sport Truck Shootout , Bowling Green, KY July 30-31, 2004.
We will again be having our Show N Shine, July 30 at the Corvette Museum followed by Drag/fun racing July 31 at Beech Bend Raceway. We are working on adding other events and activities as the weeks progress. Please visit www.454ss.com for more information and to sign up for the event
Here is a link to the official Event Site. http://www.454ss.com/sporttruckshootout/2004/index.htm with updated information, people, places to see, things to do, where to sleep for the event! Also, we have our new flyer located on the site to download and pass out to your friends and family! Or to keep and remind of this great event!
:crazy: Sign up now!
  • 2 months later...
Less then a month to go!!! Have you entered for the Show N Shine and/or the Shootout? We have hotels lined up for all of the events: Ft Wayne Indiana for the truck plant tour, My Old Kentucky Home and Bourbon tour and Bowling Green KY for the main events. :jester:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
