:cheers: I am looking for some advise. I own a 2002 Silverado Extended Cab Shortbed 2wd and put a 2" front 4" rear drop on it. I would like to put air bags in the rear to assist when I need to haul something.
Is there a kit or company out there that has a kit you guys recommend for my vehicle? I only want to put bags on the rear.
I want to keep my shocks back there and use the bags to assist only when I have a load.
Any help you can give would be great.
Both Firestone and Air Lift make rear air bags for your year and model of truck. For both those brands you have to use the "lighter duty" version, since there isn't enough clearance on the 1/2 ton trucks for the bigger bag that each of them offer.
The best price I've found for both those brands is J. C. Whitney.
JC Whitney Official Site : www.jcwhitney.com
Summit Racing also has good prices on things, but I'm not sure if they carry air bags.
gnutruk
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
