2005 GM vehicle info
endo
Some highlights:
Apparently there is now a 5.3L that makes 310hp, has an aluminum block with steel cylinder sleeves. 310hp@5200, 330lb-ft@4000. I think this is for pickups only.
They're bringing back "dark blue metallic"
There's now a wonderful new 3.23 ratio (no thanks)
The Sierra Denali gets the 345hp motor.
Touch-screen navigation is now offered in Tahoes/Subs/Yukons/Avalanches (it's a new/better navi too)
THE FRIGGIN RETARDS STILL WON'T LET YOU HAVE A G$(@#!*@)( NAVIGATION SYSTEM IN A M@#$(!@#!@#(!@# PICKUP!!!!!!!
Hybrids are now available. They don't provide ratings for the gas or electric motors though. Appears to be based on 1500 ext cab, 2wd and 4wd avail. Curb weights are 4617/5008...so the hybrid hardware doesn't weigh that much.
Anyway, full info on all of it is available here:
http://eogld.ecomm.gm.com/
Note that that is THE crappiest web site EVER. I think it was written by the guy that did hamsterdance or something. You want to go to "print book" for each vehicle to see specs on it as a PDF.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
