Burger recipies
R Dogg 56
I've always done kinda what they did on the #3 burger there...I stuff the inside of the patty. Except I stuff it with jalapenos and jack cheese.
Finely choped (almost mush) onions (vidalia's are great) , jalapenos along with a little soy sauce mixed (like a meat loaf but leave the bread for the bun) with ground round don't make them too thick.
In the corner of the grille keep a pan of water boiling inside the grille keeps the burgers moist from the steam mixing with the smoke.
Then top with blue cheese and bacon or extra sharp chedder or jack, for that matter anybodies choice of toppings is great.
Keep those good ideas coming! Here are two things I do:
I cut slices of vidalia onions, use toothpicks to hold them together, coat them with olive oil, and sprinkle with pepper. They get grilled on a cooler part of the grill.
I soak corn in the husk in water for 2-3 hours and grill it for about 15-20 minutes or until the outside husk is crispy and a bit brown. I hold it with an oven mitt to peel the husk.
my fav is to mince some raw bacon, onion and green pepper and then mix with ground sirloin and add some ranch dressing (powdered works the best, italian works good too) preheat the grill so one side is on high and center is on medium. sear for 2-4 min (depending on temp) on each side and then move to cold side to finish cooking the bacon and to lock in the juices
I like to add some Jimmy Dean pattie sausage to my beef. A 50/50 combo rocks...
That works awesome in spaghetti too. :lol:
    • These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle   video 1 - background info/explanation and part of the problem   video 2, idle misfire   I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...   Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.        Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
    • You'd want the Pulsar to be safe.  That was the first product that worked for 10 speed trucks that they came out with.   Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks     That said, in the features description of the RA003B, it does list it working with 10 speeds.  However there are reports that the RA003B can cause some drivability issues on early 10 speeds.  So the Pulsar is the safest move IMO.      Range Technology RA003B AFM/DFM Disabler   Features: Range AFM/DFM Disabler keeps you in full power 100% of the time Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system Disables Auto Start/Stop Blue LEDs The Range AFM/DFM Disabler does not reprogram factory ECU Works in hundreds of applications, 2007-2022, including 10-speed models. Leaves no trace, unplug it to return to factory settings Virtually no battery draw Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower Made in USA
    • I have a 2019 new body style high country with a 6.2l L87 and a 10 speed transmission code MQB. Looking for a disabler that is compatible. Most show it’s not. I watched a video on utube from Dons Life that says Ranges RA003B is compatible but when you go to Ranges website and check compatibility it only has a 8L90 trans listed which is an 8 speed.  I don’t want to buy the wrong one. Anyone have any experience with this situation?
    • This actually happened. Be careful where you get your information re: gas price trends.
    • I understand the principle...you don't want to spend $150 for a $0.02 piece of plastic or a little screw and perch thingy.   But this is a problem that looks like it can be reliably solved with a zip tie.   That might hold you over until you can score one at a pick-a-parts yard.
