got my 20" installed
hey guys got my new 20's installed.they handle and feel great.much better as a matter of fact than the stock 16 :troll:
thank you guys for the warm complements :cool:
i got them at "BigJim's"rims.these are the "poorman'edition.there cheaper but there polished though :lol:
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 281 Guests (See full list)
