4.2L @ 275hp and 275 ft/lbs for 2003
The 2003 4.2L I-6 is rated at 275 hp, which is up from the 2002's 270 hp. The torque is the same. Do you think they really "found" 5 more ponies in the engine, or was the engine just under-rated for 2002? Does anyone know if they made any changes that would warrant the 5hp increase? Not that I am concerned about 5hp, I guess I am just curious. Besides, if you go back and look at the old arcticles before the Trailblazer, Envoy and Bravada were released. The mags said that GM was building a 4.2L I-6 with a wopping 240 hp. I guess they were a little off at the start. Although, the 275 hp comes from GM.
Lets see if I can give you some information that I found.
1)Pistons now have a polymer coating on them; its supposed to reduce scuffing and abrasions on the cylindar walls.
2)Oil pump has been revised to lower the noise output.
3)Automatic chain tensioner has been modified to be quieter.
4)Crankshaft Torsional dampener has been changed from a dual harmonic balancer to a single torsional dampener, supposed to reduce vibrations.
5)Head gasket refinements to improve coolant flow
6)New spark plug design that gives better efficiency and durability
7)Recalibrated PCM that gives engine more control and better idle.  The variable cam can now be adjusted 24deg instead of 20deg by the PCM
I believe that most of the HP gains are through the recalibrated PCM, although the other changes are definitely nice, especially considering that the 4L60E went through some performance changes as well.  I have already talked to GM about reprogramming my PCM(Power Control Module) with the '03 code and they say its not compatible.  hmmmm.... maybe they just want you to buy a new truck... Oh well, guess I'll just wait and see what the superchip and hyperchip groups come out with.... nevertheless, all the more reasons for me to trade it in next year.  :D
Even with my Dad as the dealer trade-in next year is out of the question for me. 0% financing for 5 years. I am not going to pass that up. Plus, my Dad built my truck as a 2003 model, and it added a couple thousand bucks to the price. I already  have a PPIII from my 1996 Jimmy that I sold. Just waiting to see what they come out with and then it is back to HyperTech for re-programming.
Just a thought. Do you know if they changed the VIN code for the engine. My truck was one of the last 2002's built, I wonder where the cutoff was for the engine.
The tech post did not mention a change in VIN, and there is no change on the engine code (LL8) I do think that hypertech will be a while before they come out with PPIII for it, though just because its taken them 18mos to come out with one for the original engine, but you never know, maybe they will see that the TB/triplets are in demand and people want performance.
The cam phaser is capable of upto 25 deg.   Does it only go upto 20 degree's in 02?   I'll try to monitor it tonight and let you guys know.
Hypertech - I don't know how much performance they are going to be able to wring out.   The stock timing curve looks good.   We already shift at 6100rpm stock at WOT and Hypertech has never touched shift management (torque reduction through timing decrease) in the past.   Shift firmness is worthless on the 4L60E's and I doubt many of us will be changing rear end gears in these things.   We'll see, but it looks like GM tuned this thing as if it was a car engine and not a truck engine.    Hmmm....
It is true that it seems as though the triplets are tuned like a car, but I rode in my buddies automatic camaro, and it too has the 4L60E transmission and feels much firmer on launch and shifts, so I am pretty sure that the transmission can be vastly improved by reprogramming the PCM since thats the only difference in the two transmission.  Just a thought.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
