Well I have some overspray from someone painting on my new truck. I Waxed it the week before so most of it will come off, however there are small black {texture} spots that are also around the area. I am not sure what it is, the clay bar wont pick them up and I dont want to get grim on the clay.
Does anybody have any ideas, steam?? Luckly it is not touching paint but it is on (in) the wax.
Before you do anything, take it to the dealer first. Typically, the body shop will clean anything like this under warranty. The worst they can say is "no".
Thank you I will take it by the dealership, the contractor admited fault to the paint spray but not the black flecks that are there. Perhaps I can work something out with the dealership in the detailing department. I would have never of thought of that.
Thanks! :banghead:
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 257 Guests (See full list)
