transmission error codes
I have a 4L60E (with 2001 Vortec 5.3) in my Jeep CJ. Since I put it in, I have only had 2nd and 3rd gear where the 1st and 2nd positions put it in 2nd gear and the 3rd and drive positions put it in 3rd, with no auto shifting. I finally hooked up an ODBII connector to it this week and dumped the following codes to a scanner:
  • P0740 - Torque Converter Clutch Circuit
  • P0753 - Shift Solenoid “A” Electrical
  • P0758 - Shift Solenoid “B” Electrical
  • P0785 - Shift/Timing Solenoid
  • P1860 - TCC PWM solenoid Electrical
Has anyone ever dealt with this before? Any ideas?
Thanks.
