Cycling switch??
I've been having some Ac issues, on short trips (like a trip uptown for lunch) the Ac compressor goes off and stays off until you start moving with some speed. Under all other conditions it acts just fine. I've heard cycling switches are a fairly common part to fail, but what I don't know is what the system would act like then. Is it a replaceable part that can be done without pulling out the freon? And where is it at? The condensor is clean so I don't think it would be an airflow issue. My truck is a 02 GMC. Thanks!
The switch on the dryer does fail sometimes giving the symptoms you describe. However the harness at the switch is often the problem just as many times as the switch itself. The new body style trucks aren't as bad about it as the old ones but they still do it sometimes. With the engine running and the AC on wiggle the plug on the dryer switch and see if you can get the compressor to kick on/off by doing that. If so, you need to find another end and splice it onto the harness. I have had to do this on several trucks.
i wonder if maybe your truck is LOW on freon, maybe that's why it isn't on unless you are moving?
the switch? - on my 95 it was really easy - i simply cut the 2 wires and unscrewed it from the accumulator (i think that's what it's called) there is a schrader valve so no freon will come out.
screw the new switch in, wire crimp or solder the new wires from the switch to the wires you just cut (i don't think the color matters, but keep an eye on which one goes where) and that should be it!
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,233 Guests (See full list)
