Question about Zaino?
Getting ready to give my truck it's first Zaino experience this week and I have a question? When I'm prepairing my truck for Zaino do I wash it with Dawn, dry it off, apply the clay bar and wash it with the wash that Zaino supplied me? When using the clay bar I use Zaino Wash as a lubricant correct?
Thanks! :jester:
Wash with Dawn, dry, mix one capful of Zaino Z-7 Car Wash to 16 ozs of water for your clay lube in a spray bottle, spray the truck and use a lot of lube, after claying rewash with either Dawn or Zaino Z-7 Car Wash, dry, and you are ready to apply your Zaino. :sigh:
I just used Zaino for the first time this weekend. The instuctions said it didn't matter about doing it in the sun, so thats where I did it at. No problems. I was skeptical at first with this "primer" Z-1 and then a follow up of the Z-2. To be honest, felt like I was wasting my time because it is tough to see where you have been... my TB is white... however, and this is the good part, no white haze on the trim! :sigh: I think you could actually use it on the trim without problem... thats my plan next time.
I used Dawn, used Bug and Tar remover where I had to, rewashed those areas and dried it. Then did the "wax". I didn't buy the claybar initially, but I think I will when the car needs a deep cleaning. I can't wait to see how it holds up.
I had a C5 Corvette and I only touched it with Zaino. I used the complete system including the swirl mark remover and show car finish 2x a year. It is apain to apply, 5 coats of each - however, it turns heads!
Thanks alot!!!! Better to use Zaino in the shade or can it be applied in the sun??
:chevy:
Sun or shade it does not matter, I like doing it in the garage so the surface gets nothing on it
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 281 Guests (See full list)
