Faster airport security checkpoints
R Dogg 56
Minneapolis-St. Paul Int'l Airport to get faster security checkpoints... Other major airports to follow
So, our airport here in MN has this now, and it looks like it could go nationwide before winter. The last time I went through airport security at Christmas 2002 to go to Texas, it took about 2 hours from the time we entered the terminal(s) to when we boarded/unboarded the plane(s). From MSP to Houston to Corpus Christi/CC to Houston to Memphis {8.5 hour layover :cheers::mad::thumbs:} to MSP.
Now, that time could be significantly reduced. To me, it seems like a good idea. Your thoughts?
Last year I travelled the day before and after thanksgiving, and the 23rd and 26th of december.......The most I waited in line at Dulles on the day after christmas was 20 minutes.
I see it as a possible weakness. I guess it really depends on the thouroughness(sp) of the background check....if it's your basic background check, like the ones that people get for babysitters, that just check your criminal history, it'll be worthless. But if it's a deep deep check, like the ones people get when they have access to sensitive material at work, that's done through the gov't, then I think it'll be ok. But those will take massive amounts of time, and manpower, and money. I don't see it happening for your average air traveler.
TMF
Yeh, I've got NATO Secret security clearance and often wonder why this can't be used to somehow avoid lengthy screening delays. Good thing they use the left index finger for ID verification, I haven't had a right index finger for the last 27 years. The system could probably never handle that situation.
Still, for domestic flights I don't believe the gov't has any right to know why, where, for how long, how I paid, or who I am. As a Canadian, I am amazed how readily Americans have given in to gov't intrusion into their lives. I thought the motto was about preferring death over loss of liberty, is it now security over liberty?
Heh, my dad's in the opposite situation, he lost half of his LEFT index finger in a home woodshop accident.
On-topic for the post. I flew on July 1 and July 4 this year and experienced ZERO hold-ups at airport security, except the extra 10 seconds of scrutiny in the x-ray machine of my carry-on that was originally gonna be a checked bag. Flew ALB-Cincinnati-PDX then PDX-DTW-ALB. Didn't go back through security in the lay-over cities, only had 1 hour to grab a snack/meal before boarding the next plane. I arrived at ALB and PDX 2 hours or more before departure and ended up sitting, bored, waiting for my plane to board.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
