99 Z71 Rattling underbody
My stinking truck has been a headache since day 1--hums when I turn left--only left? ABS motor fried about 3 months ago--I am happy about that. when you shut the door the rear window pops open. Gas gauge dances around--if I jerk the truck it shows how much gas there is for real. Now the latest--it sounds like I have about 50 plastic shopping bags dragging under the truck--but only when I am going fast than 5 miles per hour. Obviously I can's get under there and see what the deal is while I am moving, so I was wondering if anyone else has had this problem and what I should be looking for. I know this is a real hard question cause it could be any of a million things, but I am really hoping someone else can give me a clue as to whether it could be my transmission and if it is going to fall out on the ground--The leaf springs are very squeeky--but I am pretty sure that they are not making this noise--more like a rubbing/flapping noise. I would appreciate any help you can offer--if only so the shop doesn't charge me an arm and a leg when I take it in. Thanks
Hums-- that has happened occasionally on mine. I think it is a surprised power steering pumps -- but it only happens spiratically... the gas guage problem is a faulty sensor in the fuel tank-- What year model is your truck?
for the plastic bag sounding noise-- check the plastic that lines the fenderwells under the hood & under the truck. if these parts are making the noise, then they will be worn down where they have been dragging or rubbing. It may only due it at 5 mph because after that speed, the wind resistance is enough to lift the piece away from whatever it's dragging against. it is possible that there is a piece hanging on the driveshaft.
Check those things, and try driving about 5mph with just the driver window down, then just the passenger window to isolate the noise more.
hope this helps
Mark
I think the noise is coming from the transmission. I checked fluid levels and then crawled under the truck and see the transmission is covered with oil. The bar coming out of the casing is actually clean for about 1/4 inch--chrome and looks brand new--like it pulled out some 'cause the rest is rusty and dirty. Oh and there was a plastic bag under there too--a newspaper got thrown between the bed and the cab--DUH. Tell me this might not cost me thousands of $'s. The truck has been rear ended twice--I mean these little rinky dink cars have driven under me and lifted the bed off the ground. Started making funny noises after the first time and has not been fixed since the second time--but it has been months since I was hit last--could being driven under caused this type of problem?
Oh and one more thing--the ABS motor went out a couple of months ago--I don't like ABS--it slips and gets mushy at all the wrong times. So at this point I pulled the fuse and just don't worry about it. I know I can have it fixed for 115 by this guy on the net, but I would just as soon leave it the way it is--is this a problem or does it matter at all? Thanks
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
