my 96 hoe...
EXJAY
Great pics!
Where did you take the pics of the OCC bikes?
OCC was here in myrle beach last year at bike week and got some
really detailed up close shots w/ my 35mm zoom also. can you
believe they left the jet/fire bikes out all night like that all week??? those pics
were taken like at 7a w/ no one around ( that i could see ). incredible
attention to detail i MUST say! bte it was the episode where the comandche chopper bike was finished and showed at the bike rally in MB. i met mikey also. :banghead:
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
