Letter from a satisfied customer
99GoldSilverado
Dear Tide,
I am writing to say what an excellent product you have! I've used it
all through my married life. My Mom always told me it was the best. Now that
I am in my fifties, I find it's even better!
In fact, about a month ago, I spilled some red wine on my new white
blouse. My inconsiderate and uncaring husband started to berate me about how
clumsy I was, and generally started becoming a pain in the neck. One thing
led to another and somehow I ended up with a lot of his blood on my white
blouse. I tried to get the stain out using a bargain detergent, but it just
wouldn't come out.
After a quick trip to the supermarket, I purchased a bottle of liquid
Tide with bleach alternative, and to my surprise and satisfaction, all of
the stains came out! In fact, the stains came out so well the detectives
who came by yesterday told me that the DNA tests on my blouse were negative
and then my attorney called and said that I would no longer be considered a
suspect in the disappearance of my husband! ! .
What a relief! Going through menopause is bad enough without being a
murder suspect!
I thank you, once again, for having such a great product.
Well, gotta go. I have to write a letter to the Hefty bag people
Sincerely,
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
