WHAT IS THIS???
5.3LSilverado01
Im realy wondering if its photochopped myself... Its just to freaky...
We disected fetal pigs in high school and they looked like little pigs, not like a farmer cross pig... (no affence to any farmers here :cheers: )
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 857 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
