Adjusting front end height
I have a 1989 GMC sierra short bed. The front end sits low. What is the easiest way to raise the front end to level the truck off? Adj. torsion bars? Any suggestions would be helpful. Thanks
Easiest way, adjust torsion bars. Wouldn't go more than 1.5", I've lowered my back down to 1" higher. Didn't like the harsh ride with all the pot holes around here. Make sure you get an alignment unless you want your tires to wear out quicker. Chris
its not the front end thats low...its your back end thats too high. put a 2" shackle on your back end and it will be even. Below is my truck with a 2" drop shackle on the back. This is from back in January.
