rear diff
In May I noticed my rear diff was overheating, so much it vented out and the smell is terribleTook it to dealer and they could not find any fault, 2000kms later on holidays, I hear noise from rear diff, took into nearest dealer and founf pinion bearings gone which required new bearings as well as crown and pinion. Replaced all under warranty. I tow 10000 pound 5th wheel, truck's towing capacity is 11000 pounds, 6 litre with 4:10 gears. After 600 mile breakin on new parts, I towed my trailer and used a laser thermometer to read diff temp. It was at 102C or approx 205F. On the way home it was 93C, I am wondering if this will continue to be a problem? Heard from a Guy at Eaton that the first 500 miles of heavy towing will wear a new pattern on the diff causing some heating, but should go away. Anyone out there shed some light on this for me?
Did you change the rear diff fluid after you first towed 500 miles?
If not that could be the reason why the rear end went bad and overheated the lube broke down
rear diff does not require a oil change after 500 miles of towing, nothing in manual for this, must have changed it for 2000 and up after they had similar problems like mine, thanks anyway.
I may be wrong, and I'll dbl check to be sure, but I thought it did tell you somewhere in the manual to change the rear diff fluid after the first 500 miles of towing.  Otherwise I don't think you have to touch it for about 50K miles.
Chappy:  I did a brief check of my manual and I didn't notice anything about changing the rear diff fluid...  hmm...  (I swear I saw it in there somewhere, but maybe I'm remembering my '00)
(Edited by Shaners at 5:34 am on Aug. 27, 2001)
Believe me if the oil was required to be changed and it wasn;t there would of been no warranty on it As it was the dealer thought that it wasn't synthetic oil and I had to set him straight. Still have no real answer why the pinion bearing went bad.Hoping this forum will shed some light on it. Thanks
Welcome to the forum Chappy, the manual on my 2000 says to change it after 500...Shaners you were right (at least on the 2000 models)....
Chappy, I looked hard in my 2001 manual and there is no mention in it about changinging the rear lube after the first 500 miles of towing.  The only mention of anything was to run conservatively in order to wear parts in under heavy load situations.  I'd say it would be a safe bet that this situation would create heat do to resistance under load.
The 2000 manual states to change the rear lube after the first 500 miles of towing.
As far as synthetic lube the answer is definatly YES!!!  The manual shows a 'tag" on the rear end that states "synthetic lube".  I don't know why your service mgr wouldn't know this?!?!?!?
I have not heard much about pinion bearings going bad on the newer GM trucks, so I think it would be safe to say you have an isolated case (unfortunate, but isolated).  As long as the dealer replaced the axle and pinion seals when he replaced the bearings and gears, I would think you'd be good to go.
One thing you might want to look at is an aftermarket rear differential cover.  They increase the fluid capacity and have cooling fins which can't hurt in helping to keep the fluid temps down.
My dad had that problem with his 98 c1500 a couple of times.  In 75k, he wore the seals out twice.  There was no paint on the rear diff after the first year.  Synthetic oil, I've heard, doesn't heat up as bad.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,397 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
