AEM Brute Force
Installed an AEM Brute Force air intake system. I love it!!
That in combination with the new Magnaflow 22" muffler, my truck drives like a different truck.
I had no idea just how restricted the "air flow" on these trucks are!
If you open it up quite a bit, there will be a slight "howl" in the cab, but it is not bad and actually sounds quite nice with the new pipes!
My truck feels like an old man who drank from the fountain of youth! LOL :banghead:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
