TIRES AND TOWING
I drive a 2004 8.1 cc 2500hd, I pull a 12500lb 5th wheel, and was wondering if anyone else is towing this amount of weight with the torsion bars turned up and some 285/75/16 BFG's TA. I have the 3.73 gearing, volant intake, flowmaster, and westers. Wondering if I should switch rear end gears to the 4.10 so I dont lose any towing power? Also wondering what oil people use in this engine? I use the penzoil 5/30w, she use a little oil about every thousand miles of towing, but Ive heard this is normal? truck has 5000 miles on it. Any suggestions are appreciated. Thanks
4.10's would help you pull a load like that one...
I hope your 285's have a load range high enough to handle the load or the truck will be unstable and possibly dangerous to drive when towing.
Most 8.1L owners seem to use about a quart of oil in between changes.
The weight will be okay, the limit is 200lbs higher per tire on the 285's, becfause they are bigger. I just dont want to lose to much power. Anyone know how much the 4.10 gears would cost to change?
I think for a 4x4 they are around $1100-$1200.
Shotgun who is one of our members did the switch to 4.56's on his truck with the 6.0L to help with his big tires and his towing capabillities.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
