TMQ
R Dogg 56
Well, the 2004 NFL season is here, and I'm taking it upon myself to keep track of what's happening around the league. I'll be posting the scores and "power rankings" of each team as the season goes every Tuesday if time allows.
Until then, here are the results from the preseason and the Hall of Fame Game, courtesy of the hdr-logo-nflnetwork.gif
Enjoy! :jester::lurk:
Hall Of Fame Game: 8/9/04
Preseason Week 1: 8/12 - 8/16
Preseason Week 2: 8/19 - 8/23
Preseason Week 3: 8/26 - 8/30
Preseason Week 4: 9/2 -9/3
  • 4 weeks later...
For those that care, sorry for not being on top on things but these last few weeks have been real strenuous for me, what with school, term papers, and a girlfriend keeping me busy. I've barely had time to keep up with my end of the deal as far as this thread is concerned, although it may not look like it on the other threads I've been on. :dupe::D
So, with that said, here are the scores from Weeks 10-12.
Enjoy! :cheers:
Week 10
Week 11
Week 12
Power Ranking for Week 10
Power Ranking for Week 11
Power Ranking for Week 12
Hey, How 'bout them Steelers!! :dupe:
Heck yeah...And Rothlesomthing setting the record for rookie wins.
If they go to the Superbowl, I get a couple of grand. I place a bet (through a buddy in Vegas) every year for them to just show up in the Superbowl.
I don't recall presently what the odds were, but they were pretty high.
That game tonight was a nail-biter though. :cheers:
But they still pulled it out.... :D Sweeeet.
