PINOUT: for S10 overhead console compass/temp
Howdy! I'm looking to put the S10 compass/temp unit in my 98 C1500. I have the unit all mounted up in my overhead and I have a temp sensor for under the hood. What I need is the pinout for the module. There is 2 plugs that go on it. Anyone have that? I'm going to make my own harness but I need to know what wires would go where. I assume it can't be too hard to do. This overhead with compass and temp is normally found in 98-99 S10 trucks. Hopefully one of you guys know the pinout or can point me in the right direction!! Thanks in advance!!! :lurk:
What's the pinout look like? What color wires and number of leads? The 99-01 S-10/Blazer mirror schematics I'm looking at doesn't have the temp in it, only compass. Does your mirror have Onstar?
Generally, the black is a ground and the green is for the reverse lamps input.
GMCSLE, he's talking about this type of unit, not a mirror.
OK, I saved the schematic from a 98 Blazer. it's directly from the GM manual, I can e-mail it directly to you, I'd rather not post it publicly. It's 403 KB....
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
