My '94
crue98
This pics shows my pin stripe. I just removed them(getting a little faded). Don't know which way I like it. I'll another pic when I get it all cleaned up.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
