Westers tuning available for the 2005 models!
Westers is now programming for most of the 2005 GM vehicles. This includes all of the GM trucks.
BENEFITS
30 day free trial. Westers will modify the program if you don't like it or you can send it back and owe nothing!
Lifetime warranty (no cost or fees)
Lifetime updates for all future mods ($45 shipping and handling fee)
Lifetime full price paid credit toward your next custom tune for your next vehicle ($45 shipping and handling fee)
No vehicle downtime! You will receive your recalibrated PCM before sending your core back. Want to upgrade this for other mods in the future? No downtime here either! The same thing can be done for this too.
HORSEPOWER GAINS:
Customers have been seeing about 24-34hp from the 5.3 28-50hp from the 6.0 and 25-55 horsepower from the 8.1 motor. The spread depends on how aggressive the tuning is along with other modifications that are done to the vehicle. Fine tuning for other mods will sometimes make more of a different than just running those with the stock programming.
Standard with all performance tunes
Complete reflash of the PCM to your VIN, with all factory updates.
Dyno developed performance tune optimized for your exact engine and transmission combination.
Raised and optimized shift points
Firm, but not harsh shifts
Elimination of all torque management that can be safely removed
Some of the more common modifications to ask for.
Raising the top speed limiter to any speed you specify
Specifying the exact shift points you want in every gear
Firmer (or softer) shifts.
Specific tuning for your modifications, like larger than stock tires, gear ratio change, aftermarket MAF sensor, supercharger, headers, cam change, engine modifications, etc.
Core charges
Westers has been trying to find a way to get customers to send their cores back quickly. There were close to 150 out as of a few weeks ago. That tends to slow production for the new customers that want to receive a computer so they have changed how core charges are handling. We will take an authorization for the core amounts listed below. This isn't an actual charge but it just authorizes that amount for us. This will be voided if your core is required to Westers within 30 days. This amount will be charged and not refunded after that period passes.
1996-2002 vehicles $150.
2003-'05 vehicles $300.
Orders can be placed online or by calling 1-877-482-9763. We can send you the custom programming form after you place your order.
well... when you punch it the throttle body only opens up about halfway or fractional power until 3000 until true wide open is then used,,,,, its messed up i prefer them using a cable throttle body for more driver precision then using a tps sensor for the pcm to monitor correct engine and transmission functions and using the engine output/ throttle position sensor output as a reference rather than only pedal position ... just a couple cents :devil:
    • It seems fine because it pulls everything out of a hot engine. I’m not going to worry about a thimble full with 5K oil changes with synthetic oil. Every other oil change is at Honda they pull the plug. I watch them through the process. It turns out going to Honda what amounts to their normal oil change intervals.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
