tires feathering in rear
okay guys heres one i just put 265s on my 04 gmc
ccd/a 2500hd i have about 1000 miles on them now
and noticing that they are feathering. now i was just
wondering if anyone else has gone threw this it sounds
to me that the rear end is staying locked up when goind
around turns that is causing the feathering just my 2 cents
wonder if there is a fix thanks :cool:
do you have the locker (g80 code, i think)? on real lockers, the inside rear tire instead of going slower then the others stays the same speed. the out side rear tire speeds up instead. not sure if gm considers limited slip rear ends posi traction, they have in the past. limited slip work like an open diff till you get on them.
I just put a set of dueller's on my 02 2500hd Crew, and I habe been watching tire wear ae well. I drive 95% on roads not much on dirt roads, after about 3000 miles I would say I have about 3/32 " wear, just under 1/8". I was suprised at how much. I bought the truck in march, and since have only put 3ooo on it, it sure is nice to live close to work, I am going to rotate them now, and probably take it to the delaer and have the rar lub. changed, under warranty of course, with syn.
Edit: I have the G80 code.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 206 Guests (See full list)
