i have a '93 350 and i want to change out the factory and get some perfomance!!!! it should do both things like give me more ft-pd without lossing but gaining some hourse power. is there anyone that has done this???? if so what type of change did you notice?!?! if you can help me it would be great :D
We have some guys here that can probably give you a good answer to this question, so I'm pushing this thread back to the top!!!
Crane Cams makes CompuCam, suppose to be able to be ECM compatiable.
However, duration staying below 220 [email protected], no more than .500 in lift, and Lobe center of not less than 112 degs should be of good compatiability with ECM.
You can always call  the manufacturer of your choice and ask for his recommendation.
:D
Might want to take a look at Edelbrock as well.  Last time I heard they had a cam and intake that were designed to be run together on the TBI 350.  Can't hurt to check them out anyways, because I know their products are good.
