E BRAKE
Going to be doing a rear brake job on my 01 1500 Sierra. Several of the forum discussions talk about a 'new' retainer clip for the e-brake. It seems that there is also a TSB on this very subject which talks about the 'new' clip in detail but does not show what they look like.
My question is, does anyone have a picture that you can post in this forum of the 'old' versus 'new' retainer clip for the rear e-brake?
Thanks Folks..
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
